need some brakes help
ok, neighbor has a 96 cruiser w/225k on it. the other day his brakes started giving him a hard time. the pedal would basically push back at him.
so we replaced the brake booster after reading online that this was likely the problem. bleeding the master cylinder took some effort as the rear port didnt really want to bleed out for a little while as opposed to the service manual saying it would bleed out after 3-4 presses. anyway, we continued on and bled all four wheels and then bled the rear load sensor port as well.
brakes were hard but the pedal would then go to the floor...assumed air still in the system.
we put it on 4 jacks and rebled. same thing. We started to suspect the master cylinder and so we got a new one and put it on. it bled out just fine but when we started bleeding the brake ports. we stopped getting fluid out of the bleed ports on the front ones??
and the pedal is still going to the floor...
any help or suggestions?? what are we missing or not doing??
I'm guessing you bled the master cylinder after replacing it? If so, then if you are not getting an fluid out of the front calipers, I would look to the ABS valve.
You would start with the master cylinder, move to ABS valve, then to the front calipers. You should be able to loosen the lines at the ABS valve to bleed it. Then move to the calipers.
You may also have damaged the master cylinder. When you bleed the brakes by pumping them, there is no pedal back pressure, and the pedal will go all the way to the floor, which means the master cylinder piston is traveling in parts of the cylinder it doesn't normally go. This normally unused part of the cylinder will most likely have a little rust that will make it rough, especially if your master cylinder is original, or even just a few years old. The rust in the master cylinder walls will shred the O-ring on the piston, and you will be either rebuilding your master cylinder, or replacing it. I know this, because I have done it.
So, I recommend using a vacuum pump method to bleed the brakes. You can however safely pump the brakes to bleed the air out, but you will need to put a block under the brake pedal at it's normal maximum travel before you start. That way you won't exceed the normal brake pedal travel while you are pumping. This may take a little longer to bleed the brakes, but will save your master cylinder.
we replaced the master cylinder with a new one though we did open up the old master cylinder as I thought along these lines as well. the rubber piston seals were weak but not torn.
just fyi in case anyone cares...neighbor couldnt be without a vehicle for the week until our schedules got back in sync to work on the truck again so he took it to a shop he trusts.
turns out the "brand new" master cylinder we put on is bad as in not new at all. shop said it had deposits and stuff all inside it which is why we didnt get any fluid to the front brakes.
when we picked it up from the parts store it was kinda dirty looking at the outset compared to what you would expect a "new" part to look like. best guess is someone bought one from there, took their old one off and cleaned it up best they could and returned it saying they didnt need it to be a cheap ass and get a free part...
just fyi.​
