need schooling on installing door glasses
Glass installation is pretty straight forward once you see how the doors come apart. There are 4 or 5 screws that need to be removed from the inside of the door panel to separate the doors. There is also an access cover and the window regulator. Remove them all. Use a rubber mallet if the door is stubborn to come apart. Remove the top chrome mount for the wing window Once the door is separated you will see the mounting frame for the bottom of the wing window. The glass and rubber fit into the opening. There is a spring loaded pivot point that fits thru the bottom frame. Put wing glass in and replace top mount. The large glass slides into the opening. The regulator arm goes into the metal glass lower track. Be sure the doors have the bottom bumper stop . It is mounted about 3 inches from the bottom of the door (2 screws). Replace the outside wiper before mounting the large glass. Replace the upper seals before putting the door back together. The all rubber seals seem better, than the metal ones. Of course they are much more $
