Need part numbers. 1991 3FE
Provo, Utah
I need the parts labeled #13 and #75 in this picture. Anybody have any idea on Toyota part #'s for these? Thanks.
Unless you are really trying to stay 100% original, you can do without that tensioner thing on the bolt. You can just do the old-school tension it with a lever technique to tension the belt, and snug it down.
Pretty sure those parts (13 & 75) are no longer available, good news is you can tension the old school way like said above.
I will eventually fabricate something, I guess. Just a little block of metal with one threaded hole and one unthreaded hole would do it. A bolt will be easy to find. In the mean time, old school it is. Thanks.
Check with @beno or @cruiserdan
If they can't get those parts, try @arcteryx (Jason at Cruiseryard)
You could also fab them yourself from a couple nuts and some threaded rod
