Need Moab Advice
i would defiantly consider getting a locker in the rear of your rig before moab.. Aussie locker - 1 hour install and $250.. DO IT!
The first time i went to moab with my truck it was on 35's stock t-case/tranny and welded rear.. I had tons of fun.. no body damage.. just watch your spotter and be smart.. The majority of any body damage you will get in moab would be if you flop the truck or roll it..
Hells revenge
Poision spider
both trails i ran with my cruiser! and one time i ran hells in a stock Cherokee XJ with 33's Open diffs and High range only Fun! lol.. See you in Moab.. Oh yea and i saw your post about driving there.. I will be heading out on I-70, so id think from durango you will be heading up 50 or something! let me know if i can help out!
Trevor
You are worrying way too much. The traction is awesome in Moab and 99% of the trails can be done no locker. If you need a quick tug over a ledge, no big deal. Maybe air down a bit more than you normally would to make up for not having a locker.
Hells Revenge--Great Choice. Like Fins and Things on steroids. Easily doable with no lockers. Do not do Hell's Gate and bypass Tip Over Challenge. Super fun, great Moab experience.
Poison Spider-Another good choice. The first waterfall turn might slow you down a bit, but hug the wall and keep moving. After that, it's all easy with a few eye opening steeps. The wedgie is not difficult. I've done the whole trail unlocked but in an 80.
Kane Creek-Harder than they say. The ledges leading up to the shelf road, and the long waterfall at the end of the shelf road were very hard for the 40s last year on our run. At least a rear locker would be good on this trail. It's fun driving in and out of the water. My rear locker solenoid died just before the last waterfall. With no lockers it was a bit dicy but I let momentum work for me. You'll become a momentum expert as well.
Fins and Things-Pure insane fun. Not as wild as Hell's Revenge, but a perfect Moab warm up run. THis should be a required first run for everyone. Did I mention it's fun? If you arn't smiling after this, go home.
Moab Rim-Stay off if unlocked.
Elephant Hill-Fun, scenic, too easy for serious 4 wheeling. If you go, the best parts are not driving. Do the hike up into Chesler Park-it's like Mars with oxygen. Then, on the way back, drive out to the confluence, then hike to the great view. This is a geologically significant spot, and you should not miss it if in the area.
Golden Spike-This is an all day adventure. DO not do it unlocked in a 40. This is by far the best trail I have done in Moab. It's worth leaving early and getting back late.
Metal Masher-not my favorite trail. Way too much slow going to get to the fun spots. I had to tug my buddy in an unlocked 60 behind me several times. Good view from the top but there are better choices.
Gold Bar Rim-the easy backside of Golden Spike. Once you've done Golden SPike-you must return to Moab down Gold Bar Rim. It's pretty tame in comparison to Golden Spike.
Behind the rocks-I'm not sure if an unlocked 40 could climb the first waterfall. Otherwise a fun trail with some sand dunes at the end.
One other bit of advice-Don't ride with anyone unless your truck is broken. The experience is way to valuable, so drive your own truck.
