Need High Beam help
Bismarck, ND
I found that my High Beams aren't working, and it may have occurred after all my front end work with the winch and bumper. I seem to have everything plugged in, but with the ARB it had some re-wiring done with the extra little lights in it.
Do they have any connections that run near or plug into any of the running lights/fog lights?
I checked, and the fuses are fine.
Thoughts?
Do your daytime driving lights work? They should be the a dimmed down version of your high beams.
Ahh. Come to think of it, they don't.
Want to be sure its not something I did when doing front end work before I have the dealer look at it.
Am I missing something really obvious?
Check your ground cables. Your headlight should have separate grounding location on each side. That is on most car I have seen anyway. Have not looked in the headlight wiring manual yet.
Check to make sure your daytime running light relay is properly connected. On my LX its by the airbox but i dont know where it is on the LC.
Also check the fuses for the two high beams.
