need help
na
i just put in my rear axle and my drive shaft is ganna be at a steep angle, im running a 350/th350/np205, so i have a short shaft, is this good or bad? im using mini axles ( I live in south FL ) only set i could find, should i try and move my rear axle back if i can, and whats the best way and cheepest way to do it? all the cruiser folks live up north, nobody is near me so im on own down here ( Homestead ) south of miami. we have a 65fj40, any help would be great.
There a few options, is the engine already moved as far forward as you can? If you wanted to get extreme you could 4-link the rear and scoot it back, you could also use FJ55 springs (I think they are longer with a centered pin), you can also get a inch or so by redrilling the spring perch. You can flip the stock springs if not already done. The only real limit is depth of pocket and fab skills.
don't forget the wrap bar and u-joint clearance. More on the FLCA side.
Bret
whats a wrap bar?, the engine is already mounted, i have no hoist so i cant move it again.if i can use 55 spring how much do they usually run? I dont have deep pockets ( military ).im not sure on the angle but the u- joint on the T-Case side is pointing down and touching. I have a CV shaft I can try and use that but its still a short shaft maybe 2ft.
24" shaft is a good length..
17" is not
Instead of 55 rear springs flip your stock springs around.. They will net you just under 3 extra inches.
As stated above, you can flip the rear springs (swap ends) and extend your wheelbase by about 4" assuming you are using FJ40 OEM or aftermarket leaf springs. What springs are on your 40? Are you SUA or SOA?
