I need help from someone in the area. I need to sell my 1977 FJ-40 but I have no idea what is a fair price. I don't want to sell it but financially it is my only option right now. If someone is in the area and could come take a look at it and knows what a fair price would be and could help me sell it I could help you out on some work or parts for your own Land Cruiser. I say that because I'm a master Toyota tech for the last 8 years at a local dealer and I know how to work on them and get parts close to cost.
So a quick low down on it.
Work Performed in last 1,200 Mi.
Front Axel Rebuilt
Inner & Outer Front Knuckle Bearings Seal, Inner Axle & Cover Wheel Hub Seal, Star Washer Gasket & Shims, Wheel Bearings, and Knuckle Bearings.
All New Brake Lines
Front Disc Brake Rotors
Front Brake Calipers
Front Brake Pads
Brake Shoe Return Spring
Rear Brake Shoes
Rear Brake Wheel Cylinders
Brake Master Cylinder
Clutch Master and Slave Cylinder
Centerforce clutch
Throw-out Bearing
Pilot Bearing
U-Joints
Rebuilt Transfer case
All the gaskets, o-rings, seals, idler shaft, needle roller bearings, bearings, freeze plug, and shims
Front Turn signals
Rear Tail lights
Rear Running Lights
Aluminum ¾ Tub
Aluminum Fenders
Sandblasted Hood, Windshield Frame, Fender Aprons, Hard top, Hard doors, Roll Bar, Seat Brackets, and miscellaneous other parts.
Engine Re-Build 19,000 Mi. ago
overhaul gasket set, pistons & rings, oil pump, freeze plugs, main bearings, connecting rod bearings, camshaft bearings, valves, valve seat grind, valve guides, valve seals, and main seals.
Also Included
Extra Jump seats
Extra Roll Bar
Hard Top (No paint and needs work)
Hard Doors (rears need work)
2 Rear heaters
Miscellaneous extra parts too many to list
If wanted 1979 Frame with Title and Vin. Plate.
Also other repairs done just not remembering at this time.
Help pleases!!
I'm in the small town of Hartland right off of 16 and North ave.
Front Axel Rebuilt
All New Brake Lines
Front Brake Pads
Rear Brake Shoes
Centerforce clutch
Throw-out Bearing
Pilot Bearing
U-Joints
Front Turn signals
Rear Tail lights
Rear Running Lights
Aluminum ¾ Tub
Aluminum Fenders
Also Included
Extra Jump seats
Extra Roll Bar
2 Rear heaters
Help pleases!!
