Need help with r12
Just got a 80 and the ac isn't very cold. I bought a 134a conversion kit at advance auto and after readign through the intructions i would have to have all my old coolant evacuated at a shop. kinda makes the whole diy kit pointless if i still need to go to a shop. After searchign the forums seems the right way is changing a few a/c parts and getting it refilled. ANyways, i decided to take the kit back and i bought a 12oz. can of dupont r12 . My question is will this be enough to get my system charged up. The air is kinda cool now but not cool enough, so i figured most the old coolant is still in there. also is the can fitting the same as 134a? or do i need a hose made specific for r12?
R12 fittings are threaded on the outside, R134a fittings are threaded on the inside.
12 oz is about 3/4 lb....maybe....What year is your cruiser?
Do not convert to 134a. You need to stay with 12 or a 12 direct replacement gas. 134a is not compatible with the oil and seals from a 12 system and has a much lower cooling capacity. If you convert to 134a, to do it right, you have alot of work to retrofit the system by draining oil, cleaning/replacing parts, and seals.
A good direct replacement gas (and inexpensive) is 401a (MP39) or 401b (MP66). I think 409a is acceptable as it is much like 401b. I have used these for years on 12 systems with great results, however there is conversion factors by the specific gas you use as to how much you put back into your system. Pay attention to your gas charts.
Your 91 should take about 32 ounces +-1.5 ounces of 12 per fsm. So... unless you have gauges to monitor head pressures it is hard to know how much you would need to put back unless you removed what you had and started fresh.
Thanks for the advice. I decided against the conversion after reading the threads about having to switch out a/c parts and flushing the system,etc. I picked up a can of r12 on ebay for $20 and a hose kit for like $10 , my buddy is epa certified or whatever so he is going to put it in for me for it to be "legal". hopefully it will be enough, I don't think it will take much as my a/c is still fairly cold, if not i will buy some more.
