need help with pulling front driveline
Battle Ground WA
I recently added 2" spacer to my 80 which already had a j springs all the way around and am now getting vibes. I would like to pull the front diveline to see if it goes away. what will have to do to not cause any damage to the tc. I don' have a cdl switch
Thanks,
get a cheap hazzard switch ($5-10) or put the tc in low to lock the cdl, then pull the CDL fuse. Then put it back into high. It will stay locked until you replace the fuse.
this is good time to hunt for a CDL switch..
I had similar issue with my previous 80 after a medium lift, and it was front drive u joint that went bad because of the increased stress. I confirmed it by locking the center and driving with front shaft disconnected.
Good luck.
is it the fuse labeled diff? just wanting to make sure
It's the largest blade fuse (30 amp IIRC) in the fuse box in the cab. Bottom right hand corner, if memory serves.
Shift into low.
Wait for CDL to lock.
Pull fuse.
Shift into high.
Drive.
(No step #6.)
cool sounds good going to pull the front ds today and see what happens
A big hammer will help. Just FYI... ;)
Ebag, of course there's a step 6. Just do it AFTER you're done driving. :beer:
