Need help with part numbers
odessa, tx
Can anyone supply the part numbers for the valves beneath the intake. Rebuilding engine and want to replace all of these in the picture. 94 fzj80
This is what I ordered as I have deleted the PAIR and EGR so I won't need those valves any longer. I ordered a new thermal vacuum valve as well.
I'm sure you've already ordered them but you can delete all of that off of your engine and in my opinion it will run better. If you search egr and pair delete there are a ton of threads on this. It will be a lot easier with the engine out. You can move the o2 sensors to the manifold while you're at it. @NLXTACY has the key chains to block everything off.
I deleted the egr and pair. I only ordered the vsv for the fuel pressure regulator and the evap(charcoal cannister). I will get rid of the rest of the stuff related to the egr and pair under the manifold
Gotcha. I should have read the details. I saw that pile of parts and thought don’t put those back on.
I considered trashing it all and just running a vacuum line to the fuel pressure regulator but I changed my mind.
