Need help with mini hub removal
I am doing a front disc brake conversion on my 72 FJ40 (Finally!!!). The mini truck front axle I have already has the nuts removed from the hub. Some info I have says remove the nuts and then the cone washers(which may require using a punch). I don't know what a cone washer is. The only thing still on the studs looks like a lock washer but none of them will move and the hub will not come off. Any advice on what I should do next.
Thanks,
Andy
those "lock" washers are acually shaped and recessed into the lockout itself to keep things tight. A few tricks work:
1> solid whacks on the side of the lockout with a brass hammer
2> tiny flat bladescrewdriver driven into the groove/gap
3> luck and cursing....
I use antisieze when I reinstall, and they are still a bitch when they come out....
Don't loose them like I did. I lost one, went to Toyota for another, they told me I had to buy a set of hubs to get them. Forkin rubberheads, thank god for junkyards. Beer, heavy cursing, and a flat head screw driving work best.
American Toyota (cruiserdan on the forum) can get individual pieces...he did for me, no problems.....
new parts??
What do you guys recommend replacing when I do the disc brake conversion. I know it depends on the condition of my parts. I checked out the marlin stuff and it seems pretty reasonable. Should I get the Knuckle service kit only or do the new wheel bearing kit also. Sorry for the newb questions. I just want to do it right but not do anything unnecessary.
Thanks
IMO, get the whole knuckle service kit....seals, gaskets, bearings, shims, etc....you WILL be pissed if you get in there and don't have a part on hand and end up ordering them separately later, the kit pricing makes it worth it.
