Need help with groaning noise
Mountaintop, Pa
Hey folks,
I have a 94 with 170K factory suspension. Stock sized tires.
On 5 out of 7 day's a week I get a groaing noise I believe is from the front end. I know I need to rebuild the birfs. I will not argue that fact. The seals leak and I have a set of birfs here to install. I've been topping off the grease once a month.
So at 50+ MPh sometimes at 40 I get a groaning noise like the front shaft is engaged and I'm running is 4wd. I jacked up the front axles and there is no play, I've removed the front driveshaft and it's still there. I've pulled both front drive plated and reset the bearing several times.
The odd thing is that when I do a sweeping right turn the sound lessons -- straight or left and it's there.
Remember sometimes it's not there at all. And if I run 70+ and stop and then drive again sometimes it's gone and sometimes it's not. Generally if it's bad if I park it for a the night the next day it's better.
I will rebuild the front end bearing and all come spring. But at the moment I do not have the parts/ time / or place to do the front end. I need to get through the winter if possible.
So, with the info on the right turn = less noise which side should I concentrate on??? I'm thinking pass.-side. I just had the DS open and no change.
Any help would be appreciated.
thanks
bob
