Need help with flashing
Abilene, Texas
My FJ40 came to me with no lights of any kind except headlights.
I installed new lights all the way around, but the signals or hazard lights will not flash.
If I tap the flasher housing lightly with a screwdriver handle, they will flash once. If I keep tapping, they will keep flashing.
Do you suspect the flasher is bad, or is there a particular amount of current draw required for it to operate that I might not be meeting?
Thanks
Either the flasher or you have too much current draw on the circuit. You ran separate circuits for front and rear with regards for left and right didn't you? ie one positive run for front right, one positive run for front left, one positive run for rear right, one positive run for rear left. Are your grounds at the lights good? Did you chassis ground them like OEM? there are a lot of variables. Before I pony up for a new flasher, Check the resistance on the circuits. make sure you have good grounds etc.
I traced down the existing wiring which was dangling underneath. Ground is good AFAIK and all the lights operate at their expected levels of brightness. I intend (but have removed it as part of troubleshooting) to run a diode affair so that I can run single signal/stop lights.
Is there a flasher out there that is a direct replacement that is more tolerant than this one?
Thanks, all.
