Need help with distributor swap
Hello,
This is a long story. I'll try to make it short. On my 79 FJ40 I am getting no spark from the coil. It is the stock distributor, coil and igniter. I think everything has current to the igniter and coil. I have a spare igniter and distributor from my FJ60 which I had replaced many years ago with a non-usa distributor.
I have already swapped the FJ60 igniter into the FJ40. That did not help. So now I am down to replacing the FJ40 distributor with the FJ60 distributor. This is a two part question. First, are the distributors interchangable? Second , is there a trick to getting the FJ40 distributor out? I Have lined it up to the top dead center mark on the flywheel and loosened the clamp and hold down bolts on the distributor. But it will not budge. Is it just really stuck or is there something holding it that I am missing. I know this is a wierd question but any thoughts or suggestions would be greatly appreciated. Thanks
After you swapped coil, is there still no spark to center tower of distributor? Check there first to eliminate coil or dist. before swapping out dist. Distributor will come out with hold down bolt removed, the drive gear will rotate as it lifts.
Be very careful upon reinstall to be sure that dist. is fully seated into oil pump. Upon restarting vehicle, verify oil pressure immediately.
Yes.
No.
Yes its really stuck. Use penetrating oil, heat and a rubber mallet on the distributor. It will come loose.
I had exact problem last week, ended up putting heat just below clamp on block, then a few taps with brass punch at base of vacuum diaphragm inlet and came right out, there was evidence of electrolysis of the aluminum to steel
How did you connect the Fj60 ignitor? it should have +12V to the wire going to coil + terminal. Other wire is tach output, doesn't need connected to anything to make truck run. Everything grounds through the mounting bolts, so make sure that is clean.
For testing purposes, it is not necessary to remove the dissy. The dissy signal genrator is self contained & isolated from the engine. A dissy can be plugged into the connector from the ignitor, then spun by hand. If there is power to coil & ignitor, the system will spark.
If no sparky, then plug the dissy into another 78-87 Cruiser that does run. Turn key on, spin dissy, watch for spark at end of coil wire.
For testing purposes, you can connect a +12V wire from batt to coil +, and a ground wire from coil bracket to batt -. Plug dissy in and spin. Coil should make serious sparkage.
Be careful, it is a powerful ignition system when working properly.
I had the same problem with my 79fj40 some years ago. After many hours of work, I found the only problem was the ground on the coil-igniter. Do what Jim said on the previous post, and hook things up directly to the battery. The factory ground through the mounting bracket to sheet metal/frame is subject to corrosion.
