- Joined
- Feb 14, 2007
- Threads
- 33
- Messages
- 205
Hi Fellas,
Can you please give me some advice on how to run my brake lines to have good articulation without tearing my brake lines off. I have a SOA and I just discovered a leak between the tube and the compression fitting on the front passenger side brake. Does anyone have advice how to properly run front brake lines for FJ40 disc brakes? Pictures would be great. Currently the brake lines run next to the firewall down the frame on each side, hard lines end by the shock tower and then there are braided lines going down to the hard line on the brake caliper. The previous owner didn't secure the lines well so they moved around a lot and in one place the braided lines are zipped tied to the bottom of the shock on each side. I really want to clean this up and make it safe.
Thanks in advance,
Roman
Thanks in advance,
Roman
