I have read through multiple threads and have probably done nothing but confuse myself.
94 LC, 209000, R134 sticker under hood from Toyota. Probably never had coolant system drained or new R134 added.
Here's my problem, about a week or two ago, noticed AC wasn't cooling well. Then during an interstate trip in 90 degree weather, started blowing warm after a pitstop for a burger.
Started diagnosing this weekend, using a food thermometer in center dash vents and OAT from iphone.
Before any work: -10 degrees from OAT.
Cleaned radiators: No change.
Cleaned evaporator using a spray foam that shoots through the drain plug: -15 degrees from OAT
Drained radiator and engine, flushed with LOTS of water, new thermostat, then replaced with Toyota Red: No change
Today put gauge on low side, initially read just under 20 psi. Here is where I screwed something up, had a can of R134 and didn't read the directions, because that would violate the man rules, and coulndn't figure out why no 134 was going in. However, I figured out....eventually....that the gauge had to be opened to allow 134 to flow, so.... attempted it again, now reading 0 psi (so I guess I drained out the 20 psi scewing around?), added both cans, with engine running, full AC on recirc, and now only reads about 5 psi.
Now NO AC. I am about to go get another bottle of R134 with oil and add that.
I don't know where sight glass is to check.
Radiator fan spins, compressor is being turned by belts. Don't know how to check anything else.
Would appreciate any help!
, but it is just plumbing. I mean, some of you guys have no qualms about replacing a birf in the middle of nowwhere or rebuilding the engine. R134a is pretty benign stuff, other than thermal burns, it takes 3 lbs of it just to be lethal to rats.
humidity or Imperial Valley in California same time, where I have been near 120 degrees, but hey, it's a dry heat.
