Need Help w/Part # for Front Passenger Door Window Switch Cover in Grey
Los Angeles
Need Help w/Part # for the Front Passenger Door Window Door Lock Combo Switch Cover in Grey.
I've only been able to locate the RHD model cover or a Single window Switch w/o the Door lock/Unlock Cutout included which is what I am after.
Your help is appreciated.
I'm not exactly sure what you're looking for but here's where I start for my searches... Yoshi Parts catalog
I'd love to see links to other places but this is the most comprehensive parts catalog I've come across and have ordered a couple items from them in the recent past.
Thank you. Very similar to Partsouq but still not sure for the Front Right side if 74231-60090-B0 is correct. If I google the part # it shows various versions excluding the one in need. Appreciate the help
I believe the last two characters are a color code. You will find several part numbers with the last two characters varying, where the difference is color of the part.
74231-60090-B0 is the correct part number and unfortunately is discontinued from Toyota. No longer available.
I'd still check with Yoshi Parts as I've ordered items from them coming from either Japan or the UAE. I did strike out on AC control module however, they showed they had one and then got a refund saying they didn't have one after all. They might have your part in stock somewhere... can't hurt to check since its a discontinued part.
