Hello all. I've run into some issues with it comes to installing an AM stereo. Yesterday I received my single din radio from Cruthfield with it's Metro connector harness went out to test the radio and got it powered np after I pulled the dash. Couldn't finish as I had to go to work and got off this morning and went to work on the project and now I can't power the radio at all. Switched back to OEM unit and still no dice no power. I figured that when I unhooked the new unit I may have hit some wires together as I was just doing a test fit since I was gonna solder them. Searched the forums and replaced the CIG, DOME and RADIO fuses and still nothing.
I started diving deeper into the dash and I found these 2 Bosch relays taped together with a red powered line running into the white harnesses blue/red wire and was taped around it. I'm guessing this isn't a Toyota addition. I followed the relay lines and it goes under the steering wheel up towards the left driver side vent and I can't follow it more than that. I started testing things with my circuit tester and on the factory white connector I have power on the 3rd upper-left side hole and no where else.
I should add but everything works on the vehicle. Lights, dash, A/C, windows, cig socket, etc.
Any suggestions? I drive an LX450 and it has the amplifier I think in the center console.
