- Joined
- Jul 12, 2005
- Threads
- 56
- Messages
- 371
HELP!!
Well -- got the engine wet - see thread below - I was "cleaning" the engine. Dummy, Dummy, Dummy
https://forum.ih8mud.com/80-series-tech/201137-whoops-got-engine-wet.html
Now I have the following codes since the Check Engine Light comes on and goes off:
83 - ECT#1
84 - ESA#1
85 - ESA#2
Local mechanic says they are categorized as communication codes. They were retrieved by "jumpering" TCE1 and E1 pins and watching the count on the "CHECK ENGINE light with the key turned to on.
My local mechanic has never encountered these codes before. The symptoms are low idle (400 rpm- used to idel at about 650), drive short distance and transmission shifts over 1000 rpm and then check engine light comes on. Drop speed and lower rpm and light goes off.
Does anybody have an Idea of the issue. I will continue to disconnect electical fittings to see if I have water in any of them AND dry them out ---
The rig operated very well before I "cleaned it"
83 - ECT#1
84 - ESA#1
85 - ESA#2
