Need help: PS pump pulley questions
MDarius
I break stuff.
Bountiful, UT
I've been in the FAQ PS Pump removal and rebuild thread and elsewhere, I'm not finding what I need.
I have a '92 FJ80 with the 3FE engine. The pulley was wobbling and when I removed it the woodruff key was shot. I bought a new woodruff key and put the pulley back on, but it still wobbles. I haven't installed it in the truck, so I'm not sure if it's supposed to wobble until it's tightened down or not. Can someone clarify that for me?
If it's NOT supposed to wobble on the shaft, I'm guessing I need a new pulley. The shaft is stable and looks good. The dealer wants $200 for a new pulley. I'm pretty sure they are out there for less than that. CruiserParts is over $100 shipped and it's going to take 10 days. Where can I find a pulley that I can get in a couple days for under $100? I've googled and not found.
Thanks in advance for any help you can offer!
I bet someone tried to pry off the pulley off before you and bent it. Maybe try to pry it back? You have nothing to lose!
The pulley itself is straight
It wobbles like the hole in the center is worn.
In that case, are you sure it's the pulley and not also the shaft?
No. The shaft LOOKS ok, but I don't have another to compare it to. Any suggestions on how to know?
All you need to do to verify the shaft geometry is measure it, using calipers or a micrometer, in at least three positions, roughly equally spaced on the diameter; if they're the same, you're good. The pulley shouldn't wobble at all. If it does, it'll be worse when you put a side load on it, which is what you do when you tighten the belt.
Posting a photo would help here. If the keyway is mangled, you have only two options: mill a larger (wider, deeper, etc.) keyway, or replace the component the damaged keyway is in. I doubt, although I can't know without seeing it, that the shaft is damaged. The pulley is softer for a reason - it's easier to replace.
If the shaft keyway is good, and the pulley keyway is damaged, you can (I wouldn't, but...) cut a wider/deeper (as necessary) keyway in the pulley and use a stepped key (will look like a "T"). In the long run, you're better off getting a new (to you) pulley.
One more thought: are you sure the pump shaft bearings are good?
HTH
HTH
Great information! Thank you, it does help. The keyway is tight, I had to press the pulley on. With the woodruff key in place there's a lot of wobble on the shaft and the shaft itself doesn't wiggle. I can't get to a picture right now, but I'll get one on here. I think I can get a caliper or micrometer for measuring pretty easily, I don't own one...yet. I should be able to reply tonight. Thanks again.
de Nada.
