Need help on cooling system...
Woodstock, GA
I have been replacing the hoses and radiator on my '79 40 and I was going to crank it up and roll it out of the garage to clean the engine last weekend, but it wouldn't start. I haven't put the radiator in yet, because after I got it I found out that it didn't come with the drain plug. It had a shiny new Toyota cap, but no plug.:doh:
Is there some sort of safety switch that won't let you crank the engine if there isn't any water in it? I didn't think there was, but it was cranking easily before I took all the stuff out and now it won't crank at all.
TIA
John Smith said:
Nope, no coolant safety anything. Your engine will happily melt itself together running without coolant. Time to start checking battery and ignition system.
I was afraid you were going to say that...
It turns over fine, but doesn't seem to fire. It did backfire through the carb once or twice when I stopped cranking it.
I wonder if it could be old gas? It's been sitting for a month or so, but I didn't think it would go bad that quick.
Thanks!
Gas doesn't go bad that quick. When it overheated was there water all over the intake? If you have a crack in your distributor cap, water will get in there pretty easy. It can condensate in there even if there isn't a crack if the conditions are just right, like hot engine and a bunch of water.
It never overheated...at least as long as I have had it. I just had to keep putting water in the radiator and had a friend put a pressure tester on it and found that the radiator and one hose were leaking so I decided to replace the hoses and the radiator. I don't like to take chances with stuff that can shut you down permanently.
I didn't think gas went bad that quickly. Condensation MIGHT be a problem, but I doubt it, 'cause I keep it in the garage all of the time.
I guess I just have to start checking things. I checked all of the fuses last night on the off chance that it was something like that. I did notice that the contacts in the fuse block are fairly dirty. I probably need to clean them up. That might even be the problem, although I tried to scrub the fuse around when I put them back in.
Thanks for the ideas!
