Need help measuring the output shaft...
The Sunshine State
Well I got a few quotes and it looks like plans are moving ahead (on the h42 as rockbox)...
What I need to do right now is measure the splines,thickness, and size so that the shop can broach a coupling for me. Ive looked around and havnt found a ton of info on it... any help would be great or at least to point me in the right direction...
-Al
Machinery’s Handbook, you should really have one for the type of work you are doing
Here is a list of values
Number of teeth
Pitch
Pressure angle
Base Diameter
Pitch Diameter
Major Diameter
Form Diameter
Minor Diameter
Circular Tooth Thickness
Max Effective
Min Actual
Number of teeth
Pitch
Pressure angle
Base Diameter
Pitch Diameter
Major Diameter
Form Diameter
Minor Diameter
Max Effective
Min Actual
ughfoo, Thats seems like it would require equipment that I dont have. Much more so than just a digital dail caliper...
....I wonder what my choices are now.
