Need Help Locating a Part
Clarksville, TN 37043
I'm restoring a 79 FJ40 and have been trying unsuccessfully to locate a couple of the long neck grommets that protect the wires and the windshield washer hose as they pass through the top of the cowl into the windshield frame.
Does anyone know of a source or an alternative product?
Thanks
the hose that goes on the heater motor of a later fj40 looks about the same its vent hose or a drain hose
I made my own. Find the appropriate sized rubber grommet and then glue your favorite rubber hose (sized correctly) to the grommet. I was very happy with how well Gorrilla super glue bonded the two rubber pieces.
Here are a couple of pictures of a Panel Pass Through grommet part # 500182 for a 7/8" hole that I found at www.americanautowire.com
The neck isn't quite a long as the OEM grommet but I believe it will be long enough to get through panels.
I'll need to split the grommet on the passenger side to get the connector for the wiper motor through it.
