Hey guys,
Hoping you might help me get this rig running. When I picked it up it would run ok after getting it started with starting fluid. Here is what has happened since then.
1. I ran the car for a few minutes to back it out of the garage.
2. I drained the oil, replaced the filter, and replaced the oil (small leak somewhere underneath)
3. Drained rear diff and transfer case and replaced with new oil
4. I thought because the choke cable is not connected, that by adjusting a screw on the carb it might help get it started without the starting fluid
5. I poured some fresh gas into the 2nd tank that was added by PO
6. My kid may have jumped in the car and moved the switch for the rear tank (I mentioned this because I wonder if this could have caused a problem)
After I changed all the fluids, while I was trying to start the car the gas pedal kind of gave way and I couldn't figure out what had happened. It wouldn't start. It would turn over and crank one time and die. I pushed it back into the garage and came back a few days later to try again.
Next attempt I realized the tension spring had broken so I flipped it around and reattached it.
I poured some gas into the carb and the car will run until the gas is burned and then it dies. It appears there is not any gas getting to the carb. I tried to prime the gas line to the carb by filling the line with gas. It wouldn't do anything again without gas being placed into the carb.
Here are some questions I have that I hope you can help with.
1. Could moving that screw on the carb have caused the rig to not stay running? It appears I didn't screw it back in far enough so I plan to adjust that at my next attempt, but could that be the problem?
2. Is this the fuel filter in the photo and can someone show me how this is supposed to look because I am pretty sure this is not the best way to have this sitting in the engine compartment? Any recommendations for a replacement (clear, OEM with some kind of mount, not sure what I need for my 2F).
3. Is it possible that my kid flipped the fuel tank switch and I got some air in the line that would cause some kind issue - do I need to prime the line from the fuel pump to the tank?
4. Is it likely that right after purchasing this 40 the fuel filter got clogged or the fuel pump failed? If so, which is more likely?
5. What is this piece on the side of the engine bay? Does it have something to do with smog equipment? There is a hose there that is not hooked up?
6. Can anyone identify the exact model of carb - wondering if I should try to pull it off and clean it out?
Thanks for any advice.
