Hi everyone, I need some help diagnosing my brake problem. The brake pedal is soft and takes a lot of travel to stop the car, but it does stop okay. While stopped, I can pump the pedal, it will harden up but slowly sink back. However, if I pump the brakes while running, the pedal hardens up but the car does not stop. After a couple of seconds the pedal will be soft again and the brakes will work again. The brake booster is also making a whistling sound that goes away when the pedal is pressed. Master cylinder has just been rebuilt, LSPV is new. Pads are new and brake fluid replaced and bled. The car is a '96 HDJ80, no ABS. Any ideas?
