need help adjusting fast idle-choke
Philadelphia, PA
1980 FJ-40, 2F in great running condition. I am having a problem with my engine conking out when I have the choke engaged. It runs great when the engine is completely warm, good idle, etc. But before that, when I am using the choke to keep the cold engine idling, it will sometimes die when I come to a stop and idle. other times the choke keeps the idle running high, which I assume is normal. This happens when it is warm, cold, etc and when I have the choke engaged halfway, which I switch to as the engine gets warmer.
Can someone school me on wether I can adjust the fast idle to correct this or not?
there should be a screw to adjust the amount of idel the choke adds.
On mine it is near the throttle shaft - probably the only screw near there other than the 'normal' idle adjustment.
Make sure you dont over adjust is so it beocomes the 'normal' idle stop - this can cause other problems alter.
