Need help accessing grounds
Southwestern CT
97 LX450 123k miles.
Having lots of electrical issues:
sometimes the door open indicator won't go off
sometimes dome lights won't go off
keyfob won't work to lock/unlock doors sometimes
electric locks will open all door locks when driving sometimes
the green circle light around the ignition key doesn't go off when driving sometimes.
Other things that have been happening since I've owned the vehicle:
rear wiper doesn't work unless hatch is open
So, from searching and reading I think I have a loose ground somewhere.
MY QUESTION!
How do I trace this down? Is there a post somewhere with photo's showing how to look for something like this. I'm a complete electrical newbie. I removed the dash panel and looked at all the wires back there, but I just don't know what to look for. I'm looking for specifics on where to look and what to look for if anyone is bored and wants to help :crybaby:
You need the EWD. It will show you where all the grounds are. You might as well order the service manual while you're at it, 1-877-762-7666.
There should be a separate diagram or several, that show where the grounds are. When I patched the ground wire to my hatch, I found the ground went all the way to a point under the shifter console. I think they minimize the number of grounds to avoid radio noise.
These are all symptom of one problem, your 80 thinks a door is open,
next time this happens open and close each door and see witch one makes the problem go away, I have a suspicion that it is the rear hatch though because of the following:
This is a problem in the harness to the rear hatch, if you open the lift gate and look near the hinges you will find 2 harnesses near the hinges, most likely your problem is going to be near where those two harnesses pass between the body and lift gate, you can also pull the lower trim of the lift gate and lok at the wiring there.
If you have no electrical knowledge unless you can find physical damage like damaged wiring you are not likely to be able to quickly isolate this problem, know anyone good with electrons?
this one may or may not be related to the others
witch dome stays on? the fore or aft? that will at least tell you witch doors you need to look at.
CT,
Start with the grounds that are attached to the front of your inner fenders. There is also one that goes from your cylinder head to the firewall. Also check the condition of the - battery cable. It connects to your block and inner fender. I had some similar problems on my '94 and even after cleaning the grounding points I ended up making a few ground straps between the frame and body(10 gauge wire with crimp on ring terminals). Now my dome light is brighter and rear wiper is a little faster. Also seems like my power windows are a little quicker. JM $.02
CT;
Yes, the EWD can be intimidating..
This is a fuse troubleshooting chart I made up for my 94-FZJ80; it should be close for the 97-FZJ80.
http://homepage.mac.com/dfmorse/FuseChart3.5.1/
Unknown to many on the forum, there is a strange problem that occurs when one of the rear brake lite bulbs SHORT out. This has to do with circuit design from Toyota. Most brake lite bulbs burn out and are open circuit; but sometimes the filament burns thru and shorts to ground, affecting 4 other circuits. Check ur brake lites and see if they are working normally.
Next, check all ur fuses to see if one or more are blown.
Now, from memory, there is a glob of connectors and wiring in the lower left rear (near where the jack & tools are located) that have been known to cause problems. Sometimes water gets into this area (rear window leak) and corrodes the connector pins, creating weird results. There are ground points here as well.
Also, under the ceiling cover at the rear, near the hatch, is a grounding point that sometimes corrodes; affecting rear wiper.
Ignition key lite is addressed here:
https://forum.ih8mud.com/showthread.php?t=93395&highlight=relay
Check all grounds under the hood that u can see. On the battery, negative terminal, there is a large black wire (#4) that goes to the engine block. There is also a smaller (#6) black wire that goes to the left fender. This is ground for the head lights and will be corroded.
At the rear of the engine is a strap ground from the engine to the fire wall, check this as well.
That is all I can think at the moment. Try to read the EWD, it takes some work to figure out what's what, but it will help ur mind to get into the thinking process.
With your symptoms my first check would be the door switches and related wiring. The switches are known to fail. The door indicator circuit is a ground circuit, so if a switch is broken or a wire is pinched/failed to ground the indication is that a door is open.
Nobody has suggested a loose staple? Most of those symptoms could be a door slightly ajar, I don't know about the rear wiper not working. Maybe that's a bad ground wire in the hatch hinge area. The staple is the staple-shaped thing in the door jamb that the door latch clamps to. If the staple gets loose or shifts or wears, the door won't close tight enough to engage the door switch. Most of your symptoms sound like a door ajar. Try pushing each door tight when you have your symptoms. Mine was the right front door. And I replaced a broken ground wire in the rear hatch.
All the "staples" are solid. However, I did have the passenger side front door latch have the plastic covering come loose on the hinge and foul up the latch. I had to grab the loose piece with pliers and yank it out. Maybe there's junk in there keeping it from latching completely. How do you take a door latch apart?
The staple may feel solid, mine did, but the door wasn't closing tight for some reason. A quick push or pull may tell.
staple? I call them bottle openers. work quite well.
Sounds like we found the problem, Rave's been opening bottles with CTs door strikers. Send him the bill, throw in some pain & suffering.
LOL,
Cannot help you with the bill but I do have something to dull the pain and suffering though, they come by the half dozen and you will need your staples to open them
Ground Problem
Sorry But I posted this to another post as well. After searching again I found this thread which also seemed the same.
I was having this problem as well, wipers didn't work, alarm having trouble arming, week dome light when on door open position and then I could not lock the doors. The doors would auto unlock as soon as I locked them. After reading threads I decided to open the back hatch panel first and look at the connectors. Simple to remove just un bolt door latch bolts 2 and then pry open the pop fitting around the plastic cover.
I just giggled the wire harness on the right side behind the wiper regulator and the alarm set and locks locked. So I removed the wiper regulator 1 bolt and looked at the harness. There was a 2 pin connector that appeared to be burnt or rusted so I pulled them apart. As I was pulling them I could here relays in the front and my 97 FZJ80 auto antena started moving. So I cleaned up the connector and put in some dielectric grease and plugged it back in. Everything worked again, wiper worked, dome light bright etc. See attched pictures.
I did not check the ground behind the roof liner driver side but am suspicious about the look of the connector. It was getting late and dark. Could this be a short to ground or just a bad coneccetion. Please Advise. Should I pull the headliner and check if everything is connected OK?
Does anyone have pictures of the ground and steps to remove the headliner? I started removing it in the dark but It got cold and hard to see.
I see no reason to pull the headliner as it appears to me that you have found the culprit, Possibly water from the window gasket dripping on the connector causing corrosion witch causes high resistance leading to overheating,
There should not be any steel or iron parts on that connector, should be tinned coper, so that cannot be red rust.
What you are seeing could in fact be rust. But it is from the water collecting minerals as it seeps through your window seal. Should almost wipe off. My '80 came from So Cal and had that rusty film on just about every surface.
thanks for the replys I felt as if it appeared overheated but I am not an electrical wizard. I'll see how it goes.
Now, from memory, there is a glob of connectors and wiring in the lower left rear (near where the jack & tools are located) that have been known to cause problems. ...
There is also a major grounding point behind the driver's side kick panel. Use a 10mm socket to remove the left foot rest first, then use your fingernails to pop up the plastic trim from the bottom of the door sill (3 plastic snap pins.) Then, up at the very top of that kickpanel cover against the firewall you will have one more 10mm retaining nut (maybe.) Remove it and the kickpanel slides right out. The ground is just inside the door edge half way up from the floor to the bottom of the dash...3 or 4 white with black wires bolted to the body.
