Need help, A442f problem
Long time looker, first time poster...
I have a '92 HDJ81v with a 4 speed a442f transmission, and 130,000 kms on it. it has a 3 inch protix lift kit and 33x12.5 r15 tires. This past few weeks i've noticed that after driving the truck for about an hour, you will feel that the body shakes/vibrates as you stop the truck with the gear lever still in the " D " position, or even when in neutral with your foot still on the brake pedal as you shift to " D " position the body will shake continously as if the truck wanted to move.then releasing the brakes slightly it continues to shake until you put slight pressure on the accelerator pedal.
i also noticed that when i accelerate harder past 2000 rpm, the battery indicator light, at/p, oil and other idiot lights on the instrument panel including the red overboost light comes on or sometimes blinks... is this related to the alternator?
cheers :beer:
check the wiring connector at bottom of alternator; a little corrosion in the connection and a little vibration from the turbo air intake can make your dash lights act like Christmas tree lights
g'luck, -Steve
It sounds like clutch chatter in a violent way. One person that does a lot of these tranny's is
Rodney at Wholesale tranny in Austlria. He has a web site Wholesale Automatic Transmissions
by your post, I have no idea where you are at. Either you have failing tranny or a poor rebuild.
Hopefully he can help you.
What were the symptoms before the rebuild?
What were your reasons for having it done?
Who did the work?
Did they re-use any parts or install all new?
How much did they charge (a rebuild for these is usually about $3k, so if it was WAY less I'd be skeptical).
Who did the work?
- sliding clutch, body shakes/vibrates when in D position while stepping on the brakes, the toyota mechanic replaced the clutch packs, reverse drum bushings and thrust washers and needle bearings.
is it possible that the engine supports and the transmission supports be the culprit? i also noticed that when i turn off the engine it shakes as if the engine was mounted directly to the chassis.
