Cruiserdrew
On the way there
It must be spring. I did the flush today as part of my pre-Moab maintence. I temporarily inserted the Prestone "T" fitting at the heater outlet with a short piece of 5/8 heater hose and 3 clamps. After screwing the hose in, I reverse flushed the heater and radiator-total non-event. After the coolant had drained and the flushing started, there was very little crud, flakes or whatever. Just a small amount of the gray stuff n the overflow bottle. I flushed about 10 minutes, opened the block drain again, flushed somemore and then let it completely drain and refilled with Toyota Red. Thermostat also got done today-very easy. In the future I'll probably do the thermostat every other year. Up till now, I've just done the drain and fill every year with Toyota Red, but the insides looked spotless, even the old thermostat. On refill, it took 3 1/2 gallons-so close enough.
Someone mentioned reusing the thermostat gasket-I wouldn't, that's a false economy. Why are there no lock washers on the thermostat housing nuts?
