Need Coolant/Temp Help!!
Calhoun, GA
I had my coolant flushed at the local dealer. I provided red coolant I had for a few years. They also reset my timing and installed the PHH.
I have the temp gauge mod, so I can monitor temp changes accurately. Since the service, my temp has ran hotter, especially after shutdown. Ambient temps in the 30's. As the pic shows, it has been about 1/8th of an inch below red a few times 5 min after shutdown.
I tested the coolant and it was pegging out the tester at -40deg. I drained a little and added water several times, thinking the ratio was bad. After adding 7 qts of distilled water, or a 50% cut, it was still testing -35deg. I'm wondering if they used something other than the red I gave them. It looked a little cloudier than the red that was in it prior to service. Maybe they put that recycled stuff in and pocketed my red??
Any suggestions? Should I drain it myself, rinse with distilled water, and start over? Could it be the timing adjustment? Any help greatly appreciated!!!
If I were you, I'd try to find a way to get an accurate reading of the coolant temperature, rather than relying on a gauge that doesn't even have numbers. Just because the gauge appears high, doesn't mean you're overheating.
Try putting a thermostat in the outlet of the water neck. My Craftsman multimeter has a thermometer function - sometimes I've taped the temperature probe to engine components & wathced the readout. Even an infrared thermometer pointed at the water outlet would be better than the stock Toyota gauge.
If you don't make many trips north, I would drain and refill with 85% water and only 15% anti-freeze. Living in Alabama, you simply don't need anthing more than 0 degree protection, certainly not -35. More water and less anti-freeze will run cooler.
