I'm done the disc brake conversion on my 69 FJ40 using Mike Smythe's write up on the S-10 master cylinder. My problem is that the brake pedal return spring brings the pedal back much quicker than the master cylinder returns, allowing the push rod to slip out of the indentation.
This happened as soon as I tried to bleed the brakes, so there is still plenty of air in the lines. The master cylinder has been bench bled following the instructions included with it. I'm using an adjustable proportioning valve from Summit on the rear circuit and it's set about in the middle right now.
Could there be so much air in the lines that the fluid just isn't pressing back fast enough? Any other ideas? The master cylinder is brand new, by the way, but it's sat in the box for a couple of years waiting on this project.
Thanks for any help. Need to have brakes before GSMTR!
