need advice on a purchase....
I just looked at a LC. The lady is asking 6000, it has 156k miles, diff locks. the body is dark green with grey trim, body has some scratches and a couple door dings. front bumper has had light impact, some time ago as the glue holding the cap on is old and yellowed. The int. isgrey as well, dirty, with a few cracks in the seats, and a driver visor that wont stay up. GGRRR. It seems to run smooth and well, no odd noises or vibrations. Heres where it turns.... I walked up to the door, she hands me the keys to test drive it, and explains that the "check engine " light has been on since she bought it. of course her friend at the mechanics shop told her not to worry about it, and clears it every time he changes the oil, then it comes back on shortly after. She offered to get it cleared and emissioned for me. Are there any common problems that this sounds like. Or did the red flag go up for a darn good reason? Any opinions would be helpful. thanks.
The year and the area of the world where this is located would be good information to give us, don't you think?
The MIL could be a lot of things. Pull the code and post back. If it is pre-OBD-II then you can pull the code with a jumper on the diagnostic port. If it is OBD-II then you might be able to get a local auto parts place to pull it. In the US, most Autozone stores will pull the code for no charge.
The driver visor will be around $200; less from Cruiserdan. He can still get the gray ones; oak/tan is discontinued. Reduce your offer by the cost to replace the visor plus another $2000 since the truck is green.
-B-
the vehicle is in boulder colo. Has been here at least 7-8 years, i think colo native. Owner said she new the original owner. i will see if i can take it to get the code read. not sure if obdII or not. what easiest way to tell? if i remember right ( no gaurantee ) i thik the build date was march or may of 96. thanks for the insight
Open the Hood. There should be a sticker on the bottom side of the hood labeled "Catalyst".
That label will usually tell you both the model year and if it is OBD-II compatible or not.
A production date of early-96 is probably a 1996 model. Which would be OBD-II compatible.
the code comes up as P0401. something about insufficient exhaust fuel resurc? cant quite remember what the guy said. does this sound familiar? what may be causing? cost of repair?
EGR, IIRC. It's common, unfortunately. Several here have battled that code and lost.
P0401 ... does this sound familiar?
Yes, I believe we have heard of the P0401 code once or twice. Try a search and see if you come up with anything. If not, let us know and someone will assist you.
-B-
so, what does that battle intail? is this a fight against the ctalytic converters? sparring with O2 sensors, or a cage fight against the computer? Or all of the above. if this is something that i could drive with, thats fine, but if it sends the car into limp mode and my mileage and performance are gonna suffer ( hahaha, i said milaege and performance ), then i dont wanna mess with it. the scan tool cleared the code, and the seller says it stays off for a couple days or so before rearing its ugly head again. i am pretty capable when throwing a wrench around, no expert, but can usually figure it out. any more thoughts?
sorry B, i think i was writing while.... yeah, looks like there is a lot of trial and error. but i can live with the light as long as it doesn't hamper anything. ill do some more searching before calling her back. :cheers:
