Need a quick 93 vs 95
Hey folks. I've been away from the forum for quite some time. I lost my '95 a few years ago in a fire. Broke my heart, but I've decided to start building another 80 series. I salvaged the ARB and 4x4labs(?) bumpers as well as some other parts off my '95 before it went off to the crusher.
I found a '93 and thinking I will start a build again. I know there are some minor exterior differences between 93-94 and 95-97. I know Slee-offroad's web site as a nice running outline of the changes between model years. But wondering if the front ARB and rear bumpers are the same between 93 and 95?
I am not 100% sure, but I pretty confident that your ARB should slide right on the frame horns up front. The Labs rear might need a little shimming here if it was built on your 95, but if it was built by Luke, then I am guessing he has a jig and it should bolt on as well.
As far as I know the frames, aside from mounts for changes to motor, trans, t-case, exhaust routing, etc. should be dang near identical.
Same dimensions and bolt holes for frame on 93 and 95. Both bumpers will work.
thanks folks. Looks like the next sound you will hear is a flushing sound coming from my bank account !!
Let it begin . . . .
one more question, not specifically the '93's.
the rig I am considering buying has the OEM security system. The key fob has been lost, the horn has been disabled, but the system is constantly activating. I assume removing the OEM security system is a well traveled path, and there are threads in the forum with a step by step process. (my '95 already had the OEM security system removed)
