Need a little Help o2 sensor
Northfield, New Jersey 08225
I have 96 lc the o2 sensor on the right side right before the caytilic converter. I think its called the no 1 heat o2 sensor in the fsm. My question is I purchased a new one and connected the power and then I placed into the mount. Now here is my problem I cannot for the life of me find the right nut to secure it.I have tried 8 different nuts from
  1. metric 8 with 1.0 pitch
  2. metric 8 with 1.25 pitch
And have tried numerous standard thread, the metric 8 fits but will not go past one turn when I place on the bolt. There is nothing in the fsm about what type of nut to use. Is this a dealer thing or can someone please help me. thanks ahead of time
So what is the correct thread pitch? Just curious.:confused:
from a bunch of different sources, some say go to the dealer some say go to autozone for metric kit and tapping set. Im going to clean it up real good and go from there. I will get the m8 1.25 again after the cleaning.
Oh and another quick question fuel injectors--------------
I got remote start for fathers day the guy who did the install told the wife that my fuel injectors needed to be cleaned. Is this possible and should he know this by doing the install.
Let me interject a quick reponse to the problem. My no1 heated o2 sensor had come loose from the fitting. It becomes quite loud, loud and more loud. Could this be what the guy was talking about?
That is my question to any and all who even read this post. Yes I am a babbler but Im in treatment for that right now.
WTF when is the sun going to come out 6 days of rain in Jersey and its starting to get me sick. Thanks eve1
That's what I thought - a good tap & die set should clear the problem. Just to be absolute sure about the thread pitch before you do it.
I just looked at my wifes o2 sensor there was a spacer on then the m8 was right on top. I guess I have to go find that spacer.
It also looks like the nut is just on maybe 1 or 2 turns. Its pretty much located on the very top of the screw with some kind of cushiony spacer holding it in place. With that said I guess the m8 pitch 1.25 is correct but i must find this mystery spacer. Does anyone know where I can get this spacer?? I dont want to stripe the bolt. Right now Im going to head over to autozone and see if anyone knows what this thing is
