Need a hub
Knee deep in hookers and gin
Blew all the studs out of my hub again. The left side one had two holes that were too wobbled out to re-thread so it was really just a matter of time.
Need one from a later model 40, 55 or a 60/2 or a mini truck. Just the part that carries the wheel bearings with the wheel mounting flange on it.
Can it be from an early @71 fj40 front? I have one on a parts doner but would need to then remove the whole truck and scrap it cause the thing won't roll and my bud might then want it out of his landscape yard. I'd be happy to grab the truck and get rid of the thing if you want the hub.
Ring me if you want me to get busy...
you can use ifs hubs, and i beleive if you do that you dont need wheel spacers
yeah everything works, you have to use the solid axle locking hub body (30 spline). But the only hick-up is it moves the rotor out about 1" so the caliper wont bolt up. So you have to either make/buy a spacer (sky-offroad IIRC carries one) to space the rotor back. Or alot of guys just move the caliper to the out side of the caliper mounting ears on the knuckle. Then they use 1/2" bolts and nylock nuts. And you grind a little off the caliper ears to make clearence for the nut-rotor. Or you can tap the caliper.
Im not sure if you must use a IFS caliper. I dont think so though.
It also gains you 1.5" of width/side
and thats why this mod is using mini-truck parts?.....
Us mini truck guys think outside the box.
