Necessary Fluid Changes
Falmouth, MA
As a newbie FJ40 owner (1970 Body, '75 2F and Tranny), I'm trying to decide what fluids need changing or just topped off. The PO had it for six years and only drove it maybe 2000 miles. I looked through the manuals I have and didn't see a service interval for most of these. Here is my list of fluids that I think are on the 40 along with my planned action.
Oil: Changed
Axle Lube: Check and top off
Clutch: Check and top off
Brake Fluid: Change?
Transmission: Check and top off
Transfer case: Check and top off
Steering gear: Check and top off
Coolant: Drain, flush and change
I'm also planning to change plugs and radiator hoses. Belts are in great shape.
Please let me know what you think of this plan.
Don't forget the front and rear differentials. If the PO ever did water crossings, water can get into the diff breathers.
Also don't forget to grease everything, especially the u-joints. I grease mine every oil change, so as not to forget.
It's a good idea to flush and replace the brake fluid every few years, but not many people do.
Change them all unless you KNOW the PO had recently done so (cheap insurance). Also check if you can what type of motor oil/gear oil was used by PO if possible. These old motors / gearboxes like a high ZDDP motor oil and a GL-4 grade of gear oil --- lots of threads on here about it. Look it up. My gearbox is noticeably smoother shifting with GL-4. Just my .02 cents.
