Nav screen stopped dimming
BC Canada
Like it says, my screen stopped dimming at night. Re-checked settings , turned auto on and off repeatedly. The lights come on and work normal at night and when I cover the sensor on the dash. Just wondering if someone has a similar experience before I disconnect the battery for a restart and then take it to the dealer. I have an obd11 and tech stream but I would be lost trying to navigate the tech stream unless the problem came up upon startup.
Just checked the dash lights and they’re not dimming either
My only recommendation would be to check the interior light dimmer. We had a similar situation where my daughter rolled it all the way. After going through all of the settings it was noticed that not just the screen was bright, but everything. So, we dialed that bad boy back down and everything was well again.
Hey, I knew that (facepalm) and I think I might have posted it once when someone else had the same problem. Thanks. All good now.
