Hey guys, I'm redoing alot of the old seals and gaskets in the front end while I reboot my CVs. And just had a question. I cannot for the life of me find a match to what I assume is the old oil seal on the outer end of the CV axle. It depresses in to the spindle. I thought I had found it in the FSM manual. But wasn't able to find a result with the information in the manual.
That's a super bad picture. I will link one when I get home that may be better. It sits on top of the brass bushing. Oil seal was the only description I could find in the FSM
I believe that the spindle needle bearings sits directly on top of the brass spindle bushing then the "Type T" oil seal that I listed above goes directly behind the brass bushing. I don't have a spare seal on hand but here is a pic of the seal from an image search.
I use my old seals after removal to drive the new seal back into the back side of the knuckle. Take care not to distort or damage it while driving them in with a steel tool/screwdriver or similar as they bend fairly easy and have a spring that can come out and be easily damaged while installing it.
