Name That Leak
Colorado
Does anyone recognize where this leak might be coming from?
Holy ***t!! That's a little more work than I had in mind!!!
A third (perhaps different) diagnoses please!!
If its not leaving trany fluid on your drive way and you don't add fluid that often then I would call it a "seep".
Personally I would not go after that one untill it gets to leaking badly.
Looked at the picture again.........rear main seal, not trany...........same fix, add oil and do the seal when you get tired of the leak.
I had a heavy leak in the same place and was going to jump the gun and have the rear main seal replaced but fortunately it was only the oil pan arch seal that failed. Check your flywheel and see if it is wet with oil if so you need the rear seal replaced if you notice in the picture of LX_TREME's flywheel you can see how the centrifugal force has flung the oil across the surface. Mine was dry and had some rust on it so I concluded it was the oil pan. I did it myself, not too hard but messy check in the FAQ for the writeup. It is nice to be able to park in the driveway again! Even nicer is not having to pay a shop $600+ to pull the tranny for a $12 seal!!
:cheers:
George
