Mystery Vibration.
Asheville NC
I have a strange vibration coming from what I can tell somewhere between the front output shaft of the transfercase and the front axle.? It only occurs when you are in that sweet spot between accelerating and decelerating and somewhat loud and you can feel it in the floor under your feet. I thought after adding a spacer to my front springs it might have been my driveline so I ordered CV shafts front and rear from Tom Woods $900 later it is still there. Could it be the front output shaft of the transfercase going bad? I have no leaks. It is difficult to shift from low to high range lately. Thanks.
Pretty similar to the vibration mine picked up when I changed the gears to 5.29's. We drained the fluid from my transfer case and it came out chunky and grey, chassis stethoscope narrowed it down to a failed bearing in the rear of the center transfer case.
I run stock driveshafts on 2.5 OME springs with 30mm spacers on top of them, verified it wasn't drivelines by running the truck on the rack with both front and rear disconnected. Noise and vibration was greatly diminished, but still there with the chassis ears on the transfer case. I picked up a wrecking yard case and will be rebuilding it to do a 1 day swap on my LX. Good luck with yours!
I have a 3" OME with a 1" spacer in the front to level it up since I have the heavy duty and it rode nose low. Im afraid the case is the problem but I think Im in denial. Good idea on running it with the drivelines removed.
I would suggest measuring from the center of your hub to the bottom of the fender flare and we can give you better advice but here's some thoughts.
1) If you have that much of a lift, you need some sort of caster correction. Without it you are likely having a hard time steering as it will dart all over. You won't know what your angles are until you do that correction, but we could help you determine where they will likely end up.
2) Once you add caster correction, if you are in the range of 4" of lift you will want to go with a DC shaft. I am actually at 3" of lift (4" lift with heavy components in front) but it still runs much better with a DC shaft. If your angles are out for the shaft you are running, you will likely get some good vibes.
3) research what those shafts mean. Tom Wood's Custom Drive Shafts - Driveline 101 The stock shaft is actually a broke back configuration so research that as well, but it operates in stock form like the conventional shaft on that site. My understanding is you have a DC or CV shaft now. Same thing as far as I know.
4) If you want to know how bad the front shaft is vibrating, remove it, put the truck in 4wd and drive it (rear wheel drive at this point) and you can isolate how much of an issue it is causing. Sometimes it's actually the rear from what I've heard.
-Edit - I see from your other thread you are running slee arms so that should fix #1 above. If you already have the DC shaft, you may also want to measure the angles and make sure it is where it should be.
Thank you. Ill take the front driveline off tomorrow and see. I'm measuring 4 degrees high on the pinion flange. Steering is actually very close to stock feeling.
Not an issue for me yet interested in your resolve. I grease my shafts until it flings all over. My cruiser likes it :) As in no vibes due to extra grease. Lol
Sorry for my ignorance but what is a dc driveshaft?
Dual Cardan (double jointed on 1 end) shaft - 3 total universals.
Caster plates are huge - I highly recommend the Landtank design that Joey vendors.
I bought mine back when Rick was direct, rotating your axle on the centerline is a marked improvement when you hit the ~4” / J’s & spacers, even coming from plates that rotate on the rear axle shell bolt.
A set of plates from @NLXTACY & a DC front shaft would be my fix, in that order.
I had the ~35mph off-throttle vibes bad when I did my 4” Slee Heavy springs, a DC shaft fixed it 100%. I was coming off a OME Heavy set/springs (2.25”) & they had no vibe, but the slight increase in shaft angle gave a whole new characteristic/ that ~35mph vibe once I was on those 4” springs, even when I was still on the old urethane OME CC bushings for a quick spin around on pavement.
The variety of tweaks done make my 4” lift handle as neutral as stock geometry, but I was obsessive getting here & was welding for a living at the time, so lots of my own welds in my undercarriage.
I have the same problem. Measuring my rear drive shaft angles this weekend. I have new 4.88’s and a dc front driveshafts and it id bad at 62-70, but noticeable at other, lower speeds. I have completely rebuilt my front axle twice, greased everything heavily. Its either t-case or rear driveshaft
How much / what kind of lift do you have?
I have an Old Man Emu 3" heavy duty but put a 1" spacer in the front so rear didn't sit so high. I ended up scrapping the caster correction and bought Slee radius arms. rotating the rear pinion until it was inline with the driveline fixed my issue.
Sounds like mebbe your preload on the rear pinion bearing may need help.
IDK your lift or miles or who did your gears, but out back pinion bearings are normally the issue.
Still on your 9” Toy axle yeah, not converted to a Dana or some other?
If you’re still Toy 9” - how did you correct the angle?
Still toyota, local guy did gears, i went and saw preload and lash before i stuck em in. My pinion angle is “stock” with a 3” lift.
Hunh. That’s really odd then.
Since you haven’t **really** moved your rear pinion angle either with shorter upper or longer lower arms on the 4-link, it should dang near have acted that way prior.
I forget, did you say if you either gave the u-joints a good shot of grease & hit the slip joint on the shft with a single pump/ enough to see the shaft barely expand?
If so, did you lift & gears all at the exact same time, or did you lift & it was fine, but went funky when you regeared? (Or vice-versa, either step being the one that “tripped the vibes”).
Lifted, had a slight noise before, now its worse with gears.
Had it with old u-joints, put in new toyota and then had a shop check both shafts and put a cv up front. Fixed nothing
OK, - did you already swap tires to the size correct to the new gears, or are the shafts now spinning a little faster with small tires & you’re correcting before new tires?
What about the grease? That’ll tell you if you need new u-joints.
It had 35’s on before and after regear. Ujoints and driveshafts are all brand new, been greased a dozen times and it makes no difference.
Well, crap. Anything now & I’m just guessing.
How about this longshot? - Unbalanced tire(s)? -or have you been there / done that for everything & now you’re ready to just throw money & parts at it all until something makes the bleeding stop?
DC rear shafts are not real common, I’m on 4” Slee Heavies (so even a little more) - smooth on my 4.88’s / 315’s & I’m corrected with slight longer lower arms and fine tuned with weld-in threaded upper arms.
Sorry man, without being there I’d be blowing smoke to confidently try to identify your culprit. Maybe you do have TC case / bearing issues.
I forget where Kevin’s shop is - maybe the smart money now is to let him diagnose in person? Nothing like being able to lay hands on all parts.
