Mystery color, please identify.
NJ
Does anybody know any details of this truck or the exact color?
Well, the problem here, and the problem for you, is that this image is an HDR image. It's NOT a photograph at all. There is NOT one single color on this image that is correct. The entire image, its shadows, its highlights, its array of color - has been digitally altered. This image, and it's merely an image, is no reference to anything.
My suggestion ? Take this image with you, on your phone, and go to an automotive paint supply, such as Sherwin-Williams or PPG or a Dupont- Axalta supply store, and go through their color chips until you cross a hue of color that you believe is similar to what you see here. Be sure to look at the color chips out in the sun. And once you find a color that you believe matches somewhat well, then go with that.
The way this image portrays the surface color, it seems a metallic paint will best suit your desire.
But someone has digitally altered a photograph through the steps of HDR, and then likely even further via a photo editing software. And this image now describes absolutely nothing - other than conjures a sense of emotion... that being yours.
If you want a Toyota color, I'd suggest looking at first at 681 Green; then Judson Green; then 6V7 Army Green; and then perhaps the line of GM greens. But keep in mind, none of them, as a solid color, will mimic the high-contrast, metallic look of this artistically altered, HDR image.
This one seems to be close :
~Skydog
~Skydog
I see. Thanks for the advice, that is a good idea.
Keep this in mind : that green (above) that you like (as presented) has a lot of yellow in it. It's a yellow-green (as opposed to a blue-green, such as being Rustic Green). So, concentrate on the yellow-greens. And look into metallics. A good color to start with would be along the lines of Eastwood's Jaded Green Metallic 3:1 single stage paint :
~Skydog
You may want to look-up photos of the Alfa Romeo concept car designed by Marcelo Gandini--it was called the Carabo, and reportedly used ground -up shells from scarab beetles to give the paint its unusual golden-green sheen and color play. HTH
