My Nightmare
phoenix, az
I have a 93' land cruiser and installed a lift consisting of 4 inch ome comp coils fr and 3 inch j springs rear from man-a-fre. After the lift I had the ever present vibration and noise. I ordered four new u-joints and had them installed as well as had the drive shafts balanced...vibration was worse than before and felt like it was binding up. The shop I was at told me that my front third member was shot. They ordered new from Toyota 3rd member for $1,500.00 and rebuilt bur fields etc..for total of $2,100.00. They took it for a test drive and it still has vibrations. We were then told that we need a new transfer case/transmission. At this point I finally started to look at the ih8mud tech forums and noticed that vibrations are common after a lift has been installed.
Unfortunately it looks like the fix for the problem is more likely a dc drive shaft and or upper rear adjustable control arms. Do I need both or just one of the two; as I don't want to spend more money than needed. It is possible that the transfer case/transmission could have been damaged during a test drive with the front drive shaft removed..I don't have the center dif. switch on dash.
gosh, it sounds like you got taken for a ride $
I would get a double cardan front shaft from Slee Offroad. What kind of caster correction do you have in there presently?
I second the DC shaft. I put 850's with my 2" spacers on front(approx 4"), w/ slee plates. Then my front driveshaft started with the vibes. I first set the splines on the shaft so that it would run in phase, instead of the OE out of phase setup. That helped a little, but the vibes (although not as bad) came in @ 40-55 MPH instead of 30-45. The DC shaft seems to be the best fix.
