I heard the same thing. Hell, those arms, especially with the axle flexed, cause some serious stress at that point! Something to consider if trying to make your own.
Don't know, found pic. Looks to be home fab arms and other stuff?![]()
From what I've been told there are at least three versions of Slee arms? The first were Outback/Slee, some had wrist joints at the chassis bushing, don't know who made them? They had some issues, the pic below is of a local, Mud member's arm, will leave it to him to claim it or not.
Second were tubular Slee units, none with the wrist. I haven't heard of any failures.
Third the currant solid machined arms, good luck breaking those heavy units!
Dang, it took me a second to figure out where the parts were supposed to be. That doesn't look like very thick tubing on the arms.
Anyone know what size tubing Slee uses in their arms? Or if they are solid?
Don't know, found pic. Looks to be home fab arms and other stuff?...
Kevin, just to clear things up, the pic with the axle twisted is not our arms, correct? It does not look like it. ...
i still say the easiest way to do the 3 link is to cut the front endmost bushing retainer off the oe arms. discard these pieces completely. what you have left is a basic pair of lower links that clear the tierod.
now weld a basic tower on the pumpkin. because the lower arms are made from modified oe arms they are low enough that the tower doesn't need to be high-a 4" lift spring would be plenty to clear the tower in this case.
weld a link mount to pass side inner fender and make the pass side upper link the exact length of a rear lower arm which are plentiful. thus you dont even need to fab an arm for the upper link-just use an extra rear lower link. make sure to get the pinion angle right the first time.
this could be built easily with the axle still on the truck
there you have it. a $75 three link you can do in a saturday
Kevin, what exactly is the difference in this setup over simply doing the "trailer hitch mod" other than correcting the castor?
Not trying to be thick or knock what you've done, just wondering as I want to fix the stock front limitations and ride comfort as well.
Thanks,
Shane
Has this been done yet? It sure sounds good.![]()
