warhorse said:With a new coil do I still have to use the ignitor?
If you have the ignitor and it is hooked up, you have the semi-transistorized ignition. That would be correct for a '76, unless modified. It can be reconnected to run without the ignitor, if need be.
You may have an ignitor problem, but if it ran fine before you replaced the points, cap, and rotor, I'd say the ignitor is OK. I'd look for a problem related to the new parts or their installation.
