my 93 wont turn .....
Tallahassee, FL
Website
www.florida4x4.com
so i noticed last time out in the woods that my truck didnt want to turn to the left too good. i checked and center to the right was like 2 1/4 turns and center to left was only 1 1/2 turns. i took the stabilizer lose to see if it was that, it wasnt. the knuckle stop bolts are ok. i flushed the steering fluid. and ended up having to replace 2 of the return hoses, pita it was. the crank bolt appears to be tight .... oil pressure is ok.
any other ideas .
thanks alot
no , no alignment .... my alignment isnt the greatest but that isnt the problem im pretty sure. this happened in the middle of a ride. just seem to lose some turn radius.
what the normal center to left and right turns .....
like i said center to right is 2 1/4 and center to left is like 1 1/2
is 2 1/4 normal ?
I think I'm about 2.5 turns from center each direction, so about 5 full turns lock-to-lock.
my two link bars are "tweaked" some from the rocks but like i said this just happened halfway through a ride in the woods. i will double check tomorrow when i take it to work ...... i noticed some of the tierods are worn a great deal , maybe one is coming apart :shrug: thanks guys
btw do the gear boxes ever go out on these things?
wellup just looked at those ... already showered so i didnt fiddle with them but visually they look secure. im gonna go ahead and make some of those niffty dom link bars ..... mine are tweaked and since this i have been wiggling stuff and seems the tie rods are shot .... hey the truck has 252,xxx miles on it....... the last 30 the hardest :p
thanks guys
ok found out was it was. seems i had a few beers last time i broke my axle and didnt clean the birf out well enough. a few balls from the broken birf was left in there and got caught up in the knuckle area. i havnt been driving it much so it didnt hurt anthing. im putting my new birf in today and found this. i kinda had it narrowed to maybe the shirt i stuffed in the axle tube to be the problem. guess i was on the right track. anyhow all is good .... cant wait to have 4x4 again :hillbilly:
thanks guys
