My 80 won't drive forward
Houston Area
So I'm coming back from a hog hunt, and 5 minutes from my house I hit a red light, so I slow down to stop at it and feel a clunk. There was a metal scraping metal sound, and now it won't drive forward in D, 2, or L, but I can reverse. What the heck!
AAA is towing me to my house. Any suggestions?
I'm still guessing caliper until it's proven not to be. You may not even need to take off the tires. Just get under and take a look. Put the truck in reverse first so that it unlocks the caliper. Again, assuming this is the issue.
I built my own front bumper and I have no rear bumper at the moment, so unless it takes those 17mm tow hook bolts, that's not happening lol.
I'll guess I'll have to pull the wheels when I get it to the house. AAA is already on the way, and I'm not busting out the scissor jacks on the side of the highway to satisfy my curiosity.
Will the caliper wiggle freely if this is the case?
Yes to the tow hook bolts.
No to needing the jack.
Yes the caliper might wiggle a little. If it moves AT ALL then you found your problem.
If it's not the caliper then if you've still got reverse then it's still got line pressure.
If it was only one gear then you'd have a single cooked set of bands or an individual cooked solenoid.
Since all forward gears have gone I'd say it is the selector on the side of the box....anything stuck in it? sticks caked mud broken cable etc. Damaged wires?
Hopefully others can chime in. I've never had Trans issues. The caliper issue I've run into twice now on other trucks.
Yup. Drove it forward until it locked up, checked both sides again. Left side was good, but right side caliper is being pinched between the wheel and the rotor.
I could kiss you right now. No homo.
So, that easy made my top 10 pucker moments, but AAA loaded up my cruiser on a flat bed and towed it to my house. Once I got there, I grabbed my ratchet set and found the caliper bolt chillin' on the back side of the hub. So I picked it up, torqued it back down on the caliper, and drove it off the flat bed.
Join us again next week for another episode of emergency mechanic, guest starring NLXTACY.
