My '77 SWB Ute build
South Australia
Hi, Sam here,
I'm new to mud, I'm from South Australia and love my old Toyotas
I recently picked up my own fj40, after growing up with a 40, 55 and an 80 it was bound to happen.
It's a '77 fj40 with a 2f, 4 speed, air locker and 33s. What makes it different though is in a previous life it was cut from a wagon into a Ute or pickup as some of you would say.
ATTACH]
This was done with a grinder, a bit of checker plate and lots of silicone to help seal the 45 roof to the hacked up 40 tub, luckily for me the silicone was the death of that tub and the previous owner purchased a 45 tub to try and fix it.
I picked it up after the PO have up on the shorty when the 45 tub needed exstensive body mods to make it fit. So I started with a complete running 40 with reasonable tub, and rust free roof, windscreen surround, chassis, bonnet
ATTACH]
Now for me is the challenge of making this all work and hopefully build myself a pretty good yota
Welcome aboard Sam!
You may want to reload your pics so we too can enjoy your rig.:cheers:
If you need any assistance please let me know and I'll be glad to help.
Yeah I do,
plans so far are to repair the tub and modify the rear of the floor to accommodate the 33s, then go over the whole thing and get it all up to standard and get out and use it
So far I've worked out were the tub is going to sit and how much I need to channel and tub the back of the tub
Currently trying to make a frame up to relocate the back cab mounts because to use the factory ones on the tub it would require a >100mm body lift in the front haha
Looking good so far, keep us posted with your progress. I'm sure others will chime in soon.
Finally worked out the amount i think i need to remove to fit the 33s, fair amount but it should never scrub.
I've also worked out my crossmember design and started fabricating it, going to run the 75x50x3mm rhs all the way across the tub floor to pick up the chassis mounts and add some strength back when I cut it,
It will have to step forward when it goes past the mounts to clear the tyres though
After getting the chassis level I set about getting the body to fit and also be level,
this ment that the old "x" shaped cab mounts had to go, as they hit the chassis, the fuel tank depression in the floor also has to be sectioned forwards to accommodate the new body mount
After working out where the new mount sits under the cab I decided to start removing the rust in that area,
The cab had rusted around the old bolt holes and the section of floor inside the rear box was paper thin, so upon the arrival of my new sheeting it started unstitching the rusted sections
I ended up removing the entire section across the back as it was all thin
I have also decided to increase my wheelbase a few inches to be the same as a MWB cruiser after doing a couple of photoshops and realising that it looks way better but still alot shorter than a normal 45/47
The SWB Ute
The MWB Ute
Hi mate.
You are in for a fun time.
Some ideas that might help you out from doing this.
My ute has a 25mm body lift and a 2inch lift with both rear corners tubed for tyre clearance.
When I was running 33 inch tyres they would only scrape the back of the tub (where it was tubed) when flexing or cornering to fast.
Then I upgraded to 35 inch tyres which would scrape bad so i installed FJ55 rear springs and relocated axle backwards about 110mm. Made big difference and also drives much nicer.
Next mod i am thinking about is redrilling the spring perch for that little bit more clearance.
Hope some of this will help you out abit.
Chris.
Hi mate.
Chris.
Hi Chris, not sure if you're still on this forum but I'min the middle of a shorty 40 build and would love to see some of your progression shots of your build or any general info for a shorty 40 ute thanks mate Simon
Hi mate.
Chris.
hi Chris I'm not sure if you are still on this forum but I thought id reach out I'm in the middle of a 40 shorty ute rebuild and would love to see some of your progression shots or get some info on shorty forty utes cheers mate see you Simon
