My 100 project
I figured I should get a build thread going since I spent a couple hours tonight shoe horning a big battery in the cruiser.
Shortly after I got her from Bamachem:
The battery has been on the down slope, and the recently kinda cold mornings have been a little tricky. It barely started over the weekend, so I picked up a Die Hard Platinum 31M.
I couldn't get around to fabbing up a bracket and everything until this evening, so I rode around ghetto with it in the floorboard in the back seat, and a set of jumper cables. That got old fast.
I went out to my father in law's shop this evening, and my bro in law and I knocked out the install in a couple of hours. We got a little silly with part of it, which you'll see in a bit.
First step was to see if it fit. Yup, plenty of room:
The next step was to extend the positive terminal so that the right angle part would fit on the oversized battery. From the threads on here, it looked like folks used copper bar stock. I used a 2.5" piece of 1" x 1/4" bar.
The next step was to slim down the end that goes on the wiring harness to fit in the channel that it clamps in. We could have used a grinder, but we thought it'd be a lot cooler, totally unnecessary, and complete overkill to have a machined piece. Over to the mill...
Then over to the wire wheel on the grinder to clean it up and get it ready to go.
While I was at it, I figured cleaning up the mating surface on the terminal wouldn't be a bad idea.
Fit on the terminal was good.
Next step was to get the tie down strap ready to go. I used a 2" x 1/8" piece of mild steel bar stock, and bent it on the brake to fit the contour of the battery and line up with the factory tie down j-bolt and front bolt.
Next I cut two 5" sections of 2" x 1/8" angle to use on the tie down, and welded it up.
My welding skills aren't that great, but they're looked functional enough. I tacked everything, and then test fit. Then I ran one as a full bead, but got worried about the piece warping, so I did the others a half at a time and rotated through to finish it up.
And lastly, bolt everything down and start her up.
It starts really quickly now. Big improvement.
Nice work!
Doesn't look like that battery is going anywhere.
Just did this same mod on my 100, Man does it start fast now!
Yeah, it's way faster. I'm kinda wanting to get the last 10% out of it, it still turns over a couple of times before it fires. I know that's nit picky, just now that it's all beefy and all, it has me wanting to tinker. I'm not sure what I'd do, injectors and plugs or something. It's not worth it I know.
Yeah, I took a couple of panic brake / swerves to see if it moved. Nothin. ;)
I'm cruisin' 280 this evening with my moms, she's in town. And I spot a Badass hunnerd ahead. I get giddy, cause it's an awesome color, then I see a D shackle hanging from the hitch.... Damnit! That's Keith!!!!
fuggin awesome rig you have! Maybe I don't want the navy blue...
Thanks man!
I saw WOOPOW pass me, then I saw someone wave out the passenger side, and thought, "Wonder if that's Hagan and Zack headed up to ACC or wherever?"
Then it was, "Is Zack wearing a wig? Wait... nevermind."
Next on the list is some not-bald tires, and pull the running boards.
After that, maybe some drawers. I've got a couple sheets of plywood in the basement that would be just about right for that I think.
Also need to modify the battery tie-down and notch the top so that just in case the battery slides towards the driver side, the strap doesn't ground do the + terminal. That'd be bad.
I only wear a wig when I'm at the house...
Although I have been seen in public in a skit...
Sent usin the "new" app.
Tires went on today. 275/70/18 Toyo Open Country MT's. Downside, one of the center caps came off apparently on the ride home. I gave cdan a call to see about getting another one. Mike at Lovelady Automotive said to just let them know what it cost me and they'd make it up on the next time I'm in there, which I thought was nice of them.
Sam Stewart at Lowe Toyota in GA gives same discount and is a lot closer
Man. Needed that 20 min ago. Oh well it's on its way now.
Second on the Sam Stewart vote.
Can you post up Sam Stewart's contact info?
375 South Houston Lake Road Warner Robins, GA 31088
(478) 971-5693
ask for Sam. thats how I got him. I have new belts and a OEM air filter to install this weekend.
Free shipping too.
I think he is in the vendor section.
Man... all this insult added to injury. And here I thought I was getting the hookup. Oh well. Part was (about) $33 and change, and the guys in brown shorts got $9 to bring it to me. Lesson learned.
i dont know how Sam doesnt lose his ass by offering free shipping... my parts were only 45 bucks or so, shipping would have cost him around 10 dollars, but I took delivery in person.
Water pump, hoses, and OEM radiator cap here. I always e-mail him. He bent over backwards trying to find the water pump studs for my 3FE.
He probably does lose his ass on shipping, but their UPS / FedEx account probably does so much volume that it's not tracked on an individual order basis.
Part sells for more than cost of goods? Yup.
FedEx / UPS Bill this month was less than gross profit on mail order parts? (from other non 'mud customers paying for shipping, and possibly a handling charge) Yup. - Then it's all good.
That's my speculation at least. Their parts business on the whole is probably a lot bigger than the 'mud crowd, and makes up for it. Meanwhile, they get lots of reputation and recommendations on here for being really friendly, going above and beyond, and having great prices. Win, win, and win.
I will say, if it's free shipping, closer, and the same price for the part, that makes a customer out of me the next time I need something.
