I know I have posted this on here before but I thought i would post some up of just the mount for those that want to go this route. I no longer have this mount as it was sold to a fellow mudder but i do still have some of the pics so here it goes.
I built a mount that used the factory holes back there minus 2 holes that i drilled in the bottom of the corner pannel for extra strength but you could easily build the same mount and use the heavy duty adhesive tape. Basically the mount that holds the two compressors together is very simple. I cut small angle iron to the lenth of the compressor which i drilled holes in where the holes in the feet of the compressor where. Then i welded some small tabs on the bottom of these where the compressor below has bolts holding the compressor together. The bottom mount is simply a tray made or angle that mounts in the space and bolts to the holes on the metal lip of the truck.
