Mud Claw MT
houston
Anyone have experience with these tires? The local tire shop said they're a Cooper off-brand. Not sure if that's true or not.
Anyone have insight or experience?
FWIW Cooper does a ton of other brand stuff. Pro Comps are probably the most common. In my experience they are pretty weak in the sidewalls if you intend to do any low air pressure driving. I've had a couple sidewalls start to fail because the steel threads would break and then protrude through the sidewalls. When you see steel fibers sticking out - it's usually time to toss them. I've also ripped the sidewalls out of a couple. I worked at a tire shop and could buy Cooper 35's for under $100 each, so I kept using them back then.
I don't have any knowledge of those specifically though.
